Selca G873 Touch /copying probe measuring cycle in space
Contents
G873 [X...] [Y...] [Z...] [I...] [F...] [R]
Parameter | Description |
X,Y,Z | expected coordinates of the point to be measured. |
I | clearance. |
F | measuring cycle feed rate. |
R | rapid move up to I… mm from the expected point. If I is not programmed, the entire move will be executed at the programmed feed rate. |
Enabled: only in the block inwhich it is programmed.
