Selca G877 Limits, mode and copying plane
Contents
G877 PLANE K... J...
Parameter | Description |
PLANE | plane on which the polygon defining the copying area limits lies (XY or YZ or XZ). |
K | defines copying plane: K0 = XY plane. K1 = ZX plane. K2 = YZ plane. |
J | defines scanning mode: J0 manual scanning. J1 parallel bi-directional passes and step increments perpendicular to the passes. J2 parallel bi-directional passes and step increments at an angle with respect to the passes. J3 parallel unidirectional passes and rapid return performed at a clearance height. J4 parallel unidirectional passes and rapid return performed at a clearance height (with Z down inhibit). J5 plane profile with increments on the perpendicular axis at completion of each pass. J7 probe qualification cycle. J8 radial bi-directional passes rotating about a point. J9 radial unidirectional passes with rapid return performed at a clearance height. J10 radial unidirectional passes with rapid return performed at a clearance height (with Z down inhibit). J11 3-D contouring along a programmed profile. |
