Selca G883 Digitizing cycle
Contents
G883 I... J... K... Q... [D0=...] [D1=...] [AXES] LNAME:
Parameter | Description |
I | chordal error – maximum allowable error between the theoretic curve and the segmented line linking the stored points (I = 0.02 by default). |
J | maximum chord length (J = 1 by default). |
K | point storing format: K0 ASCII format (default). K1 S3000 binary format (only for S3000 Series CNCs). K2 S1200 binary format (only for S3000 Series CNCs). |
Q | minimum chord length (Q=0.4). |
D0=0 | enables continuous point storing in manual copying mode (default value). |
D0=1 | enables point storing under operator’s control in manual copying mode. |
D1=0 | digitizing with probe deflection compensation (default value). |
D1=1 | digitizing without probe deflection compensation. |
D1=2 | digitizing and direction cosine storing with probe deflection compensation. Example: X…Y…Z…I…J…K… |
D1=3 | digitizing and direction cosine storing without probe deflection compensation. Example: X…Y…Z…I…J…K… |
AXES | name of the axes (maximum 4) to be stored. If omitted, the system storesXYZ: XY: only X Y are stored. XYZC: X Y ZCare stored. |
NAME | name of the program where the digitized data are stored. For the S3000 Series: For the S4000 Series: |
Enabled: until a G882 with different parameters is programmed.
