Selca G884 Copying parameters for unidirectional passes / Radial copying parameters
Selca G884 Copying parameters for unidirectional passes (3, 4, 9 and 10 copying modes)
G884 X... Y... Z... I... J... R
ParameterDescription
X or Y or Zabsolute coordinate for probe rapid repositioning between the passes.
Iprobe retraction travel covered at copying speed (I=3mm by default).
Jprobe approaching travel covered at copying speed (last part of probe rapid repositioning between the passes) (J=3 mm by default).
Rprobe retraction and repositioning in rapid.
Selca G884 Radial copying parameters
Selca G884 Radial copying parameters (8, 9, 10 copying modes)
G884 [X...] [Y...] [Z...] [Q...]
X,Y,Z(X… Y… or X… Z… or Y… Z…) coordinates of pass rotation center (pole) (pole inside copying limits).
Qlimit angle for copying cycle end. The default value is Q=180° with respect to the starting angle. Incremental programming is possible by adding I to the angle.
