Selca G889 Copying probe data
Contents
G889 I... J... K... Q... [X...] [Y...] [Z...] [D0=] [D1=1]
Parameter | Description |
I | nominal deflexion on the plane. |
J | probe tracer point radius. |
K | probe orientation (in G17): K1 parallel to X in theX+direction. K2 parallel to X in the X- direction. K3 parallel to Y in theY+direction. K4 parallel to Y in the Y- direction. K5 parallel to Z in theZ+direction. K6 parallel to Z in the Z- direction. The 1,2,3,4,5, 6 codes can be prefixed by additional 1,2,3,.. Codes; for example K14, K24, K34, etc. This way 24 codes are obtained, allowing to rotated the probe from its current position to any other position. (see par. 4.2 of the Digitzing and Copying Manual). |
Q | Q0 with qualification cycle. Q1 without qualification cycle. Q.. descent depth of the probe on the qualification cube through G877 J7. |
X,Y,Z | definition of a plane parallel to the copying limit plane: Z… For limits on XY, Y… for limits on XZ, X… for limits on YZ. This plane shall be always programmed. |
D0 | coefficient of friction. |
D1=1 | enables the special parameters for direct copying. |
Enabled: until a G889 with different parameters is programmed.
