SINUMERIK 840D Programming
This blog post is about sinumerik 840D cnc control from Siemens. This post illustrates one of the loop commands (control structures), which we can use in cnc programming for sinumerik 840D cnc control.
There are multiple control structures which can be used in Sinumerik 840D programming like
- IF
- LOOP
- FOR
- WHILE
- REPEAT
CNC Program Example
G01 G90 X0 Z10 F1000 WHILE $AA_IM[X] <= 100 G1 G91 X10 F500 G1 G90 Z–20 F100 Z5 ENDWHILE
Explanation Of CNC Program
This cnc program cuts a slot (can be used for drilling) on the component face. The cnc program starts from x0 and goes till x100 every time taking a cut in x-axis of 10.
G01 : Linear Interpolation
G90 : Absolute Programming
G91 : Incremental Programming
The first cnc program block takes tool to starting position. Which is x-axis x0 and z-axis z10.
The second cnc program block checks if the x-axis current position is less then or is equal to 100 with sinumerik 840D system variable, and start a WHILE loop.
Then tool travel is x-axis 10 from the current position. (Because G91 Incremental Programming is active, So tool will travel as taking the current tool position as the reference point (or start point).)
Then our tool travel -20 in z-axis (Now G90 Absolute Programming is active so tool will travel with reference to the work piece zero point.)
Now again the tool will be back at z5
The ENDWHILE ends the WHILE loop
So the program will be repeated again and again until the statement which is given with WHILE becomes FALSE.
