Sinumerik Alarm 120308 In the event of an emergency stop, the program %1 can only be changed in the machine/program correction area.
%1 = Program name with path
Switch to the machine area and change the program with the program correction function. The alarm disappears automatically as soon as a program is edited or simulated in the program area. The alarm can also be acknowledged manually via diagnostics.
Internal
