Sinumerik Alarm 300413 Error when reading a file (%1, %2)
%1 = Error code 1
%2 = Error code 2
An attempt to read a data block, e.g. a drive boot file, from the file system has failed. The data block or the file system is damaged.
If the error occurred during power-up, i.e. it is probably connected to a drive boot file, delete all boot files and load them back into the control from the back-up copy.
