Sinumerik Alarm 300500 Axis %1 drive %2 system error, error codes %3, %4
%1 = NC axis number
%3 = Error code 1
%4 = Error code 2
The drive has signaled a system error. Safety Integrated: Request: In the corresponding cycle. On FDD: Generator stop (corresponds to STOP B) On MSD: Pulse and servo disable (corresponds to STOP A) The error occurs if the computation time of the drive processor is not sufficient for the cycle indicated in the additional information. Error no.: 03, additional information: 40, monitoring cycle too small for SINUMERIK Safety Integrated.
Notes on the error codes can be found under Section “Error codes of alarm 300500” in the SINUMERIK 840D/840Di/810D Diagnostics Guide. NCK reset (POWER ON) The search for the precise cause of error can only be performed by the development team. The displayed error codes are always needed for this. Reinitialization of the drive required. Please inform the authorized personnel/service department. (contact SIEMENS AG, Sys- tem Support for A&D MC products, Hotline (Tel.: see alarm 1000) Safety Integrated: Increase the corresponding cycle or the cascade cycle (e.g. current, speed, position control cycle) or deselect the functions which are not required.
