Sinumerik Alarm 300614 Axis %1 drive %2 time monitoring of motor temperature
%1 = NC axis number
The motor temperature (measured via the temperature sensor KTY 84 and fed to the module through the motor encoder cable) has exceeded the temperature limit in drive MD 1602: $MD_MOTOR_TEMP_WARN_LIMIT for a longer period of time than permitted in drive machine data 1603 $MD_MOTOR_TEMP_ALARM_TIME. $MD_MOTOR_TEMP_ALARM_TIME (time stage motor temperature alarm). The alarm can be reprogrammed in the MD ALARM_REACTION_CHAN_NOREADY (channel not ready).
– Mode group not ready.
• Motor overloaded.
• Check the motor data. Possibly the machine current was too high as a result of incorrect motor data.
• Check the temperature sensor.
• Check the motor encoder cable.
• Check the motor fan.
• Motor encoder defective.
• Check the acceleration.
• If necessary, use a higher-performance motor.
• Winding fault in motor.
• 611D control module defective.
• Modify MD 1230: $MD_TORQUE_LIMIT (1st torque limit), MD 1235: POWER_LIMIT (1st power limit) set too high.
