Sinumerik Alarm 300705 Axis %1 drive %2 position controller cycle time invalid
%1 = NC axis number
The monitor in the 611D module has detected a position controller pulse rate which is beyond the permissible limits. The conditions for a permissible position controller pulse rate are:
1. Minimum cycle period: 250µs (810D 312.5µs)
2. Maximum pulse rate: 4 s 3. The position controller pulse rate must be a multiple of the speed controller cycle given in the drive MD 1001: $MD_SPEEDCTRL_CYCLE_TIME.
Change the position controller pulse rate on the NC.
