Sinumerik Alarm 300710 Axis %1 drive %2 position controller cycle times of axes differ
%1 = NC axis number
In a 2-axis module, the position controller cycle for the two axes is not the same. This alarm can only occur with OEM users having the 611D drives without the standard NCK interface. This would make it possible to transfer axially different position controller cycles to the 611D module.
Please inform the authorized personnel/service department. Set an identical position controller cycle for both axes.
