Sinumerik Alarm 300723 Axis %1 drive %2 STS configuration of axes differ
%1 = NC axis number
The configuration of the control block MD 1003: $MD_STS_CONFIG (STS configuration) must be identical for both axes on 2-axis modules.
Please inform the authorized personnel/service department. Check drive MD 1003: $MD_STS_CONFIG (STS configuration) and set the bits for the two axes of the module so that they are the same. (Do not change the default setting – this corresponds to the optimum configuration).
