Sinumerik Alarm 300735 Axis %1 drive %2 field weakening speed invalid
%1 = NC axis number
The value in MD 1142: $MD_FIELD_WEAKENING_SPEED (threshold speed for field weakening) is less than or equal to zero.
Please inform the authorized personnel/service department. For standard motors: Reset the drive (delete the bootfile) and repeat the startup. For third-party motors: Check and, if necessary, refer to the motor data sheet to correct MD 1142: $MD_FIELD_WEAKENING_SPEED (threshold speed for field weakening).
