Sinumerik Alarm 300787 Axis %1 drive %2 asynchronous mode: feedforward control gain out of range
%1 = NC axis number
If motor inertia and motor nominal torque have been selected unfavorably, the asynchronous motor feedforward control gain is beyond the range of the internal number format. The alarm can be reprogrammed in the MD ALARM_REACTION_CHAN_NOREADY (channel not ready).
• Operation without encoder: Reduce the number of encoder lines in MD 1005: $MD_ENC_RESOL_MOTOR (encoder resolution for motor measuring system), since this has an impact on the internal number format.
• Optional/additional measure: see operation with encoder
• Operation with encoder: Reduce speed controller cycle MD 1001: $MD_SPEEDCTRL_CYCLE_TIME (speed controller cycle).
