Sinumerik Alarm 301710 Axis %1 drive %2 resolution SSI motor measuring system invalid
%1 = NC axis number
The configuration of the motor measuring system for an SSI encoder is incorrect: MD_1022 $MD_ENC_ABS_RESOL_MOTOR must not be 0.
– Mode group not ready.
• Set MD_1022 $MD_ENC_ABS_RESOL_MOTOR to the correct value:
• Rotary encoder: Singleturn resolution (increments per revolution).
• Linear encoder: Resolution of an increment (in nanometers).
