Sinumerik Alarm 310607 Axis %1 drive %2 valve not responding
%1 = NC axis number
The valve is not responding to the valve slide setpoint. Cause: valve not connected or valve has no valve slide checkback signal.
– Mode group not ready.
• Valve without valve slide checkback signal: Modify MD 5530: reset bit 2
• Check the valve connection.
