Sinumerik Alarm 310707 Axis %1 drive %2 STS configuration of axes differ
%1 = NC axis number
The configuration of the control block MD 5003: STS_CONFIG (STS configuration) must be identical for both axes on 2-axis modules.
Check drive MD 5003: STS_CONFIG (STS configuration) and set the bits for the two axes of the module so that they are the same. (Do not change the default setting – this corresponds to the optimum configuration).
