Sinumerik Alarm 310772 Axis %1 drive %2 gain in rough area of valve characteristic is less than or equal to zero
%1 = NC axis number
The gradient in the coarse area of the valve characteristic is less than or equal to zero.
The gradient in the coarse area is calculated as follows:
• Positive quadrant: (MD 5485 – MD 5464) / (MD 5486 -5465)
• Negative quadrant: (MD 5487 – MD 5467) / (MD 5488 – 5468) Enter a valid combination in the above drive MD.
