Sinumerik CYCLE84 Rigid Tapping Cycle
CYCLE84 produces tapped holes without using a floating tapholder.
CYCLE84 can be applied only if the spindle designated for drilling is capable of working in the position-controlled spindle mode.
CYCLE84(RTP, RFP, SDIS, DP, DPR, DTB, SDAC, MPIT,PIT, POSS, SST, SST1)
ParameterDescription
RTPReturn plane (absolute)
RFPReference plane (absolute)
SDISSafety distance (enter without sign)
DPFinal drilling depth/elongated hole depth/slot depth/pocket depth (absolute)
DPRFinal drilling depth/elongated hole depth/slot depth/pocket depth relative to reference plane (enter without sign)
DTBDwell time at final drilling depth (chip breaking)
SDACDirection of rotation after end of cycle Values: 3, 4 or 5
MPITThread pitch as thread size – 3 (for M3) … 48 (for M48)
PITThread pitch; values: 0.001 … 2000.000 mm
POSSSpindle position for oriented spindle stop in cycle (in degrees)
SSTSpeed for tapping
SST1Speed for return
