Sinumerik LONGHOLE Elongated holes on a circle
With Sinumerik LONGHOLE cycle, elongated holes can be produced arranged on a circle.
The width of the elongated hole is determined by the tool diameter.
LONGHOLE (RTP, RFP, SDIS, DP, DPR, NUM, LENG,
CPA, CPO, RAD, STA1, INDA, FFD, FFP1, MID)
Parameter | Description |
RTP | Return plane (absolute) |
RFP | Reference plane (absolute) |
SDIS | Safety distance (enter without sign) |
DP | Final drilling depth/elongated hole depth/slot depth/pocket depth (absolute) |
DPR | Final drilling depth/elongated hole depth/slot depth/pocket depth relative to reference plane (enter without sign) |
NUM | Number of holes/elongated holes/slots |
LENG | Length of elongated hole/slot length/pocket length (without sign) |
CPA | Center point circle/pocket, abscissa (absolute) |
CPO | Center point circle/pocket, ordinate (absolute) |
RAD | Radius of circle (enter without sign) |
STA1 | Starting angle Values: -180 to 180 degrees |
INDA | Indexing angle |
FFD | Feedrate for depth infeed |
FFP1 | Feedrate for surface machining |
MID | Maximum insertion depth for insertion (enter without sign) |
