Sinumerik SLOT2 Circumferential slot
With Sinumerik SLOT2 cycle, circular slots can be produced arranged on a circle.
Sinumerik SLOT2 cycle is a combined roughing/finishing cycle.
SLOT2 (RTP, RFP, SDIS, DP, DPR, NUM, AFSL, WID,
CPA, CPO, RAD, STA1, INDA, FFD, FFP1, MID, CDIR,
FAL, VARI, MIDF, FFP2, SSF)
Parameter | Description |
RTP | Return plane (absolute) |
RFP | Reference plane (absolute) |
SDIS | Safety distance (enter without sign) |
DP | Final drilling depth/elongated hole depth/slot depth/pocket depth (absolute) |
DPR | Final drilling depth/elongated hole depth/slot depth/pocket depth relative to reference plane (enter without sign) |
NUM | Number of holes/elongated holes/slots |
AFSL | Angle for slot length (enter without sign) |
WID | Slot width/pocket width (enter without sign) |
CPA | Center point circle/pocket, abscissa (absolute) |
CPO | Center point circle/pocket, ordinate (absolute) |
RAD | Radius of circle (enter without sign) |
STA1 | Starting angle, values: -180 to 180 degrees |
INDA | Indexing angle |
FFD | Feedrate for depth infeed |
FFP1 | Feedrate for surface machining |
MID | Maximum insertion depth for insertion (enter without sign) |
CDIR | Direction of machining Values: 2 (for G2) 3 (for G3) |
FAL | Correct finishing allowance for contour (enter without sign) |
VARI | Machining mode 0=complete machining 1=solid machining to finishing allowance 2=only machining of finishing allowance |
MIDF | Maximum insertion depth for final allowance |
FFP2 | Feedrate for final allowance |
SSF | Speed during finishing |
