Sodick Wire EDM
Sodick Wire Cutting EDM CNC Programming Example
N005 G54 (SELECT COORDINATE SYSTEM A00) N010 G92 X.250 Y-.300 (SET PROGRAM ZERO) N015 G90 (SELECT ABSOLUTE MODE) N020 C411 (SELECT CUTTING CONDITION) N025 G42 H061 (SELECT RIGHT OFFSET AND…
Sodick Wire EDM G Codes M Codes
Complete G Codes M Codes lists for Sodick Wire EDM with Mark 25 Mark 21 CNC controls. List of G Codes G Code Description G00 Rapid Motion (appears as a…
Wire EDM Programming Example
Complete cnc programming example for machinists who work on a Wire EDM machine (Electrical Discharge Machining) CNC Wire Cut Introduction Wire EDM cutting, also known as electrical discharge machining, is…
