A machine tool which does primarily turning, but which has live tooling (a spindle on the turret) for doing milling operations. From a software point of view, a turning center is made possible by the NC’s ability to do transmit and cylindrical transformations. The modern spindle drive, which can function equally well as a rotary, contouring axis also makes turning centers economically attractive. Some turning centers have an Y-axis as well.
More ...
Haas ST-10Y CNC Turning Center with Y-Axis and a Small-Footprint
Your cnc machine workshop mostly machine small and innovative parts, then why use behemoth cnc machines?. For small parts use small cnc machines, because using a small cnc will surely…
CNC Lathe Live Tooling Definition and Related Haas CNC M-Codes
ContentsCNC Lathe Live Tooling DefinitionHaas CNC Lathe Live Tooling M-CodesM133 Live Tool Drive ForwardM134 Live Tool Drive ReverseM135 Live Tool Drive StopM14 Clamp Main Spindle / M15 Unclamp Main SpindleM19 Orient SpindleM154…
G-Code G94 Feed Per Minute
Feed Per Minute (G94) G94 G-code is a modal G-code. G94 instructs the control to interpret feed commands as inches/minute or mm/minute for linear moves. degrees/minute for rotary moves. inches/minute or mm/minute…
CNC Turning Center Programming Example
Easy to understand CNC turning center/cnc lathe programming example for cnc machinists who work on cnc turning centers/cnc lathe machines. This cnc programming example can be used as a cnc…
C-Axis Lathe Programming Example with Live Tooling on Haas CNC
ContentsLive Tooling Lathe Programming with C-AxisC-Axis Lathe Programming ExampleCNC Code Explanation Live Tooling Lathe Programming with C-Axis This is a live tooling lathe programming example which shows the use of…
Live Tooling Lathe Programming Code – Spindle Orientation Haas CNC
ContentsLive Tooling Lathe ProgrammingLive Tooling Program Example CodeCNC Program Code Explanation Live Tooling Lathe Programming This is a live tooling lathe programming example which shows the use of driven tool…
G81 C-axis
Haas CNC Parameters Live Tooling with G81, G82, G83, G85, G89, G95 Cycles
ContentsHaas CNC Cycles G81, G82, G83, G85, G89, G95 with Live ToolingHaas CNC Parameter 315 bit 1 (NO SPIND CAN CYCLE)Haas CNC Lathe Parameter 315 bit 1 Set to 1Haas CNC…
Automatic Tool Presetter on Haas CNC Turning Center
ContentsHaas CNC Turning Center Automatic Tool PresetterHow-to Tool Offset Setting – SINUMERIK 808D TurningFanuc CNC Control Tool Offset Procedure Haas CNC Turning Center Automatic Tool Presetter This video briefly describes…
M19 Spindle Orientation – M119 Sub Spindle Orientation
ContentsM19 Spindle OrientationUsage of Spindle OrientationM19 Spindle Orientation on FanucM19 Spindle Orientation on Haas CNCM119 Sub Spindle Orientation M19 Spindle Orientation M19 Spindle orientation. M19 M-code stops the spindle in…
Taper Turning with G90 Modal Turning Cycle – CNC Example Code
ContentsG90 Modal Turning CycleWhat is ModalG90 Turning Cycle UsageTaper Turning with G90 Turning CycleCNC Program ExampleTool Path ExplanationAlternative of G90 Turning Cycle G90 Modal Turning Cycle G90 Turning Cycle is briefly…
A Clear View for Coolant-Intensive Machining with Rotary Wiper Spin Window
CNC machining with 5000 RPMs and with high coolant pressure, what else a cnc machinist want, CLEAR VIEW of what is happening inside machine. Yes of course due to high…
Haas CNC Lathe M-Codes
HAAS CNC Lathe Miscellaneous Functions M-Code Description M00 Program Stop – Modal M01 Optional Program Stop – Modal M02 Program End – Modal M03 Spindle on Forward (S) – Modal M04 Spindle on Reverse…
G90 Turning Cycle Step Turning Program Fanuc 0-TC
Fanuc 0-TC tutorial explaining how to make a cnc program for Step Turning with G90 Turning Cycle ContentsFanuc G90 Turning CycleFanuc G90 Cycle Example Fanuc G90 Turning Cycle G90 Turning…
Siemens Sinumerik 808D Turning Overview
SINUMERIK 808D Turning CNC is perfectly tailored to meet the requirements of modern standard turning machines. Intelligent CNC features such as full servo controlled rigid tapping or flying spindle/C axis…
G90 Turning Cycle
ContentsG90 Turning Cycle FormatProgrammingParametersIncremental ValuesWorking/ OperationCNC Program ExampleCode ExplanationCancellation of G90 Turning CycleG90 Turning Cycle vs G71 Turning Cycle G90 Turning Cycle Format G90 turning cycle is called with many names…
Doosan MX series M-Codes – Doosan CNC Turning Center Programming
Doosan MX series M-code list for cnc machinists/programmers. M-Codes for both Upper unit and lower unit are given. ContentsDoosan MX Series CNCDoosan MX Series M-Code List Doosan MX Series CNC This list…
Anilam 4200T M Codes CNC Turning
Anilam 4200T M-Codes list for cnc machinists programmers who work on CNC Turning machines with Anilam 4200T CNC controls. ContentsWhat is M Code (Miscellaneous Function)Anilam 4200T M Codes What is…
General Turning Insert Nomenclature for CNC Dummies
General turning inserts come in variety of shapes and sizes. One thing is important to remember and understand is that every turning insert has a nomenclature associated with it. These general…
Fanuc 31i G Codes Machining Center – Fanuc 30i 31i 32i
Fanuc 31i G codes list for cnc machinists programmers who work on cnc machining centers with Fanuc 30i 31i 32i cnc controls. ContentsFanuc CNC ControlsFanuc 31i G Codes Fanuc CNC Controls…
