Yaskawa Yasnac 3000G alarm codes complete list.
Yasnac 3000G Alarm Codes
- 11 EXCESSIVE TEMPERATURE RISE IN THE PANEL
- 12 TAPE/MEMORY HORIZONTAL PARITY ERROR
- 13 TAPE VERTICAL PARITY ERROR
- 14 FORMAT ERROR
- 15 DATA ERROR
- 16 OFFSET ERROR
- 17 PARAMETER ERROR
- 18 TAPE MEMORY ERROR
- 21 OVERTRAVEL
- 22 REFERENCE ZERO RETURN AREA ERROR
- 23 REFERENCE ZERO RETURN UNREADY
- 24 REFERENCE ZERO RETURN POSITION ERROR
- 25 SEQUENCE ERROR
- 26 SPINDLE ERROR
- 27 POSITIONING ERROR
- 28 MACHINE UNREADY
- 31 SERVO POWER UNSUPPLIED
- 32 CONTROL UNIT UNREADY
- 33 EMERGENCY STOP
- 34 SERVO ERROR
- 35 OVERLOAD
- 36 FEEDBACK ERROR
- 37 HARDWARE ERROR (FG ERROR)
- 38 HARDWARE ERROR (RPG ERROR)
- 81 CPU ERROR
- 82 MEMORY COLLATING ERROR
- 91 CONTENTS OF DISAGREEMENT OF TAPE AND MEMORY (FOR OFF-LINE ONLY)
- 92 TAPE READING ERROR (FOR OFF-LINE ONLY)
- 114 BUFFER REGISTER OVERFLOW
- 115 F CODE UNSPECIFIED
- 214 COMMANDING OF UNUSABLE G CODE
- 215 ERRONEOUS PROGRAMMING OF G CODE
- 314 ADDRESS SEARCH ERROR
- 315 NO DATA FOR OPERATION
- 414 COMMANDING OF UNUSABLE CHARACTERS
- 415 SUBPROGRAM ERROR
- 514 TOOL OFFSET TAPE INPUT ERROR
- 515 CIRCULAR ARC PROGRAMMING ERROR (G02/G03)
- 615 TOOL RADIUS COMPENSATION C ERROR
- 715 COMPUTING ERROR
- 815 AXIS OR R DESIGNATION ERROR
- 915 M, S, OR T CODE DESIGNATION ERROR
- 1015 TAPE MEMORY CAPACITY ERROR
- 1115 AREA CHECK ERROR
- 1215 G28 OR G29 PROGRAMMING ERROR
- 1514 RESET UNREADY
